ReNamer:Pascal Script:Basic Conversion Routines
Navigation   Arrow Return.png ReNamer:Pascal Script
Basic Conversion Routines or How to serialize files
In this chapter we will take a look on serialization.
Converting Integer to the String
All we need to serialize filenames is integer variable and a way to convert the number into a string. This type of convertion is done by IntToStr function. Convertion is necessary as FileName is a string and anything we want to add to a FileName must be also a string.
In the following script we will add serialized number in front of the FileName.
  i: Integer;
  FileName := IntToStr(i) + '_' + FileName;
  i := i + 1;
This script always serialize from 0 to "infinity". It's because all the variables are set to their default values when you press Preview. And the default value for integers is 0. Would you mind trying to rewrite this script so it would start to serialize from 1? It's enough to swap the main two lines of code.
  i := i + 1;
Now i is incremented from default 0 to 1 before the first filename is changed. For now we can serialize from 0 or 1. How to start from a different number will be covered in the next chapter.
Converting String to the Integer
And what if we have filenames that already start from a two-digit number and we want to increase these numbers by 2?
We need to extract the number from the FileName string, convert it to the integer, increase by 2 and then convert back to the string. It means we would need the StrToInt function which is the complete opposition to already known IntToStr.
  i: Integer;
  Number: String;
  Number := Copy(FileName, 1, 2);
  i := StrToInt(Number);
  i := i + 2;
  FileName := IntToStr(i) + WideCopy(FileName, 3, Length(FileName)-2);
Beware, if the string passed to StrToInt function cannot be converted into integer, function will fail and preview procedure will be terminated with an error message.
If that doesn't suit us and we want to handle those cases, we can use StrToIntDef function that apart from the string takes the default integer value as a parameter and returns that value on failure. So we could use it like this:
  i := StrToIntDef(Number, -1);
  if i <> -1 then ...
