Hi Den;
Long time no see;
I've tried to use the Renamer for inserting "Date Picture Taken";
but under --> insert --> Insert Meta Tag
I could not find that option;
Is it hidden somewhere else;
Or I cannot use the Renamer to insert "Date Picture Taken"?
Mekdam
How about a little searching before posting?
Hi Andrew;
I’ve tried it;
You are right; this is GREAT;
Can I suggest adding something
When I add a prefix for the date in a folder;
In order to have the photos in the same order of (EXIF DATE);
The name should be in the following sequence; Year-Month-Day
Currently Renamer uses the following sequence; Day-Month-Year
Or can the user have the option to which order he/she want the order?
Mekdam
Mekdam, that's very simple to do indeed!
Just press F8 while in the program (or go to the Settings Menu / All Settings), select the Meta Tags tab, change the Date Format as shown below and Save. That should do the trick for you!
This is really awesome;
Mekdam
