I have in a folder a lot of camera picture realized with 3 different type of camera (.jpg files). So file name prefix are differents. I would like rename these file by considering shooting date time stored into the picture itself (Exif data, I have the possibility to make this type of sorting into PaintShop - pro, but only for internal use ).
Is it possible to do that with Renamer? If yes could explain how to do it?
Many Thanks
André
This program is wonderfull ![]()
Just add a rule, Meta file tag, Exif date as a prefix!
Hi André and welcome to the forum
If yes could explain how to do it?Many Thanks
André
André> Is it possible to do that with Renamer?
Yes ![]()
André> I would like rename these file ... date time ... Exif data,
You can take your original file name and prefix them with meta data, or put this to the end, or in the
middle, or.... you can even delete the whole current file name, what do you want?
If you want to exchange the file name completely by meta data...
1.) ADD RULE DELETE, set it to "from Pos. 1" and "till the end", skip extension (to remove the whole name)
2.) ADD RULE INSERT, press "Insert Meta Tag", chose your desired data (to make this your new name)
3.) press PREVIEW (to see if this fits your needs)
Note: you can format the meta tag by using menu "Settings > Meta Tags"
HTH?
André, that's the wrong way... you're faster then i ![]()
Fine you found it yourself, that's the best to get familiar ![]()
See you
Andrè > This program is wonderfull big_smile
I agree ![]()
