I have been using your program with great success on Windows XP, now have it installed and can't get it to work.
What I am doing is using WebRipper to rip pdf files from a server and when it does it puts 1- in front of all the files.
So I setup a simple delete of the 1st 2 characters and it apply's to the entire folder of files. When I tell it to rename
I get the error 0 files successfully renamed. 1666 files failed to rename! State column shows green check and red X
Is the program itself not compatible with Vista?
Is there some security that is blocking the rename process I can shut off??
Thanks!!
Stacy
How about a screenshot of the failed rename process so we can see if you've specified something wrong or not?
It might be a problem with priveleges rights or files locking.
Even on XP you will get similar results if system or other application will not allow to rename file(s).
But if you can rename these files manualy (with Windows), then such behaviour of ReNamer is strange.
Yes, this is most probably the security/permissions issue...
Right-click on the folder that you are renaming the files too, select 'Properties' -> and uncheck 'Read-Only'.... (if it's checked), had the same problem on Vista... this fixed it.
cdnrec, thanks for the solution!
