#1 2008-05-22 20:15
sdrule
Monitor system/application events
I want to suggest you a simple (i think) feature:
execute what you need (e.g. system shutdown) when in windows system/application events register happens a specific event number. Naturally you have to not consider previous events compared to shutter start.
Thank you for your good job.:D
#2 2008-06-21 13:27
Re: Monitor system/application events
This should be possible, but why would you need those events? They are very low level, and are mostly not for the user's concern.
MSDN wrote:
Windows Events are typically used for troubleshooting application and driver software...
Can you clarify that this feature is useful, for example, by describing your own case?
