#1 2007-09-26 22:53
bart
What is this "http://192.168.xx.xx/screenshot" ?
thank you for this very useful little soft : I use it every day for my network !
Question : sometimes, I need to use the "screenshot" function to see if a job is finished or not in another computer.
But when I have done 10 or 20 (I didn't count !) screenshot, the screen is white and I have this :
Then, it is impossible to get a new screenshot untill I reboot My own PC ... not very usefull smile
Sorry for my poor English ... but is it possible to avoid this problem ??
Thank you for help !
#2 2007-09-27 01:23
Re: What is this "http://192.168.xx.xx/screenshot" ?
Thanks for reporting this issue!
I have discovered the problem, and fixed it in the latest development version: ShutterBeta.zip
Try it, and tell me how it goes, ok?
#3 2007-09-27 10:02
bart
MERCI +++ for answer and your work !!!
I deleted all content of the old folder, unzipped new content.
Then I had to re-install the previous .ini, your beta .exe seems not to create a new one when I tried to save settings ? Is it normal ?
Anyway, the bug seems to be solved, I'll tell you more in a couple of days.
smile
#4 2007-09-27 10:42
You could've just unpacked it into the original folder, because all what Archive/Installer has is 1 DLL and 1 EXE, without INI.
Shutter saves its settings into INI file when you close it...
#5 2007-09-27 10:49
bart
euh ... it didn't do it, when I closed the program, no INI where created. I knew it previously and tried it...
Perhaps a local bug, don't worry, all is ok now smile
#6 2007-09-27 10:51
Strange... maybe it doesn't have permissions to write to the directory??
I just tried it on mine, launched Shutter and closed it straight away. INI file was created.
#7 2007-09-27 11:26
bart
Perhaps ? My OS  is WinXP home SP2.
#8 2007-09-27 12:30
Try unpacking it on your Desktop... Run and Close, then check INI.
Do you have administrative rights on that computer?
#9 2007-09-27 13:29
bart
Yes I have admin rights.
It works ok on my desktop, .ini is created.
I think I found something about it : the folder "shutter" is a "hidden folder". When I uncheck "hidden" option for this folder, .ini is created ...
roll don't know why... I'm not working in Microsoft Cie !
Thx ++  for help ! It works very well now.
#10 2007-09-30 21:33
It must be one of those strange things about Windows wink
