#1 2023-01-23 17:21
Gregg78
Search and Replace inside files
Hi there,
I would like to know if, with ReNamer or another tool like this one, it's possible to search and replace characteres?
Everyday I have to replace characters like this one "é" to his HTML symbol "é" in multiple files.
Thank you for your help and your time!
Gregg
#2 2023-01-23 19:37
Re: Search and Replace inside files
Hi and welcome.
There are many tools to modify the content of a file (even including some text editors).
ReNamer is a tool dedicated for to modify the name of a file.
But with the help of PascalScript you can do content modifications with ReNamer too:
https://www.den4b.com/forum/viewtopic.php?id=167
For more advanced work we would recommend a more dedicated tool for that wok.
http://www.den4b.com/forum/viewtopic.php?id=98
#3 2023-01-24 11:28
Try AstroGrep for searching and GrepWin for search and replace operations.
Notepad++ also has ability to search and replace content across files, but it is a bit less intuitive for that particular operation.
