#1 2022-11-03 17:47
adostrom
Drag and drop is broken
I don't know whether it is the upgrade to V7.4, or a Windows 11 update, but I can no longer drag and drop files into Renamer.  This has worked fine for years and recently stopped working.  I am running Renamer V7.4 (latest) and Windows 11 Version 22H2 Build 25231.1000.  It has not worked for several insider builds, though.  Drag and drop works fine in other programs.
Thanks.
#2 2022-11-03 18:19
Re: Drag and drop is broken
It sounds like an issue with Windows 11, but let's investigate...
Can you create a short video to demonstrate the issue?
Also, try using an alternative file explorer as the source for the drag & drop operation, for example Explorer++.
#3 2022-11-04 20:36
adostrom wrote:
. . .  I can no longer drag and drop files into Renamer.  . . .
Do you perhaps run ReNamer with elevated admin rights (from a shortcut and checked "[x] Run As Admin") ?
#4 2022-11-05 17:05
adostrom
Yes, it runs with elevated admin rights and has for years and years.
#5 2022-11-05 17:09
adostrom
I'll create the video if you want.
#6 2022-11-06 09:12
Can't reproduce your issue.
Tested on Windows 11 22H2 build 22621.755 with ReNamer 7.4.
Note that the drag & drop may not work if you are running ReNamer under a different user account to the one used by the source of the drag & drop operation. This is a security feature of Windows.
#7 2022-11-07 18:17
adostrom
I can reproduce and I have created a video.  As you will see, I can drag/drop to/from Explorer/Explorer++, and from Everything, and other apps that support drag and drop work fine.
Update - I de-selected "Run as Administrator" and now it works.  I'm not sure why it was set up that way, but I think it will work without admin privs.
#8 2022-11-07 18:26
adostrom
Update to my update - I tried running MP3tag with admin privs and drag and drop doesn't work then, either.
BUT...
What it does do is put up the little circle with a slash symbol to say it can't do the requested drop, while ReNamer just doesn't do anything.  I think that the way they do it is much better, so you understand that it is not broken, but unable to complete the task/
What's strange is that ReNamer has been in use for years and always worked until recently.
