#1 2020-06-22 19:29
Torsten01
Use ReNamer only for a part of the filename
Dear experts, I have a question.
I have filenames like
"Left PART-Right PART of THE first fileNAME 001"
I want to leave the left part (before the hyphen) unchanged.
Is there a possibility to set the rules in ReNamer that it only changes the right part, after the hyphen?
I want to remove the spaces and "captitalize and preserve" the right part of the filenames (after the hyphen).
"Left PART-RightPARTOfTHEFirstFileNAME001"
Best regards
Torsten
#2 2020-06-22 22:32
Re: Use ReNamer only for a part of the filename
Currently, there is no easy way to apply rules only to a part of the filename.
However, your task can be accomplished with the Pascal Script rule, using a script below:
  HyphenPos: Integer;
  BaseName, PartLeft, PartRight: WideString;
  HyphenPos := WidePos('-', FileName);
  if HyphenPos > 0 then
    BaseName := WideStripExtension(FileName);
    PartLeft := WideCopy(BaseName, 1, HyphenPos);
    PartRight := WideCopy(BaseName, HyphenPos+1, WideLength(BaseName));
    PartRight := ReplaceRegEx(PartRight, '\b(\w)', '\u$1', False, True);
    PartRight := WideReplaceStr(PartRight, ' ', '');
    FileName := PartLeft + PartRight + WideExtractFileExt(FileName);
#3 2020-06-23 19:06
Torsten01
Thank you very much for the Pascal Script. It's exactly doing what I want smile
#4 2020-06-23 22:46
By the way, you can learn more about the scripting features at our Pascal Script wiki article.
#5 2020-06-24 18:56
Torsten01
Thank you for this hint. I am not really able to write scripts in Pascal but I understand the script you have created except the following line: "PartRight := ReplaceRegEx(PartRight, '\b(\w)', '\u$1', False, True);"
Could you explain to me what "'\b(\w)', '\u$1', False, True" is doing?
#6 2020-06-24 19:29
ReplaceRegEx() >>> https://www.den4b.com/wiki/ReNamer:Pasc … xpressions
ReplaceRegEx(Input, Find     , Replace, CaseSensitive, UseSubstitution);
ReplaceRegEx(Input, '\b(\w)', '\u$1'   , CaseSensitive, UseSubstitution);
\b + \w + \u >>> https://www.den4b.com/wiki/ReNamer:Regular_Expressions
For "(...) and $1" >>> see there at "Substitution of text using backreference"
Means: find one sign of "an alphanumeric character" at a "word boundary" and capture the match in (...) parentheses
for reuse later by $1, which has the option \u to "Convert all characters to upper case".
So match the first sign of an word and change the case to upper, if need or not.
#7 2020-06-24 19:38
Torsten01
Thank you very much!
