#1 2007-05-02 14:19
tiagomelo
Unsure about how can i rename these files
I want to use rename to process a lot of photographs, i want the path be like this
yyyy/mm - mmmm/dd/yyyy.mm.dd - (last 4 characters of the filename).(extension)
All the dates shown here are of :EXIF_data:.
There is a way that i can do this besides pascal script?
Thank´s, your program is very helpful smile
#2 2007-05-02 15:43
Re: Unsure about how can i rename these files
You are on the right direction, use :EXIF_Date: tag, but change it's format to the one that you want. This can be done in Settings (main menu). There is only one problem: at the moment, date format must contain only valid filename characters, which means that you can't use "\" in there.
Don't worry, here is a workaround for you, just use these steps:
1) Set date/time format to: yyyy$mm - mmmm$dd$yyyy.mm.dd
(you will later replace dollar signs with path delimiters)
2) Add Delete rule: from position 1, till the end, skip extension
(this will clear the original name, and will leave only extension)
3) Add Insert rule, with :EXIF_Date: tag
4) Add Replace rule, replacing "$" with "\"
This should do it! ReNamer will automatically created folders.
P.S. Test it on small number of files first!
