#1 2014-07-02 03:39
simon.H
Connection failed when Shutter running as a service
I want to connect to shutter web mode.
but when i run shutter by service my remote computer
Many conneting failed  to shutter web mode.
(sometimes i success, at least one in ten connecting)
When i run shutter by normal (not service mode), i always can connect shuter web mode.
What problem  on my case ?
Please check my question.
Thanks.
#2 2014-07-02 19:30
Re: Connection failed when Shutter running as a service
First, make sure you read this article: http://www.den4b.com/wiki/Shutter:Run_as_service
Running Shutter as a service is not officially supported, but if you provide more details we might be able to help you.
1) What method to you use to run Shutter as a service?
2) Have you tried other methods, mentioned on the Wiki (link above)?
3) What error message do you see when you open Shutter's web interface in the browser?
#3 2014-07-03 04:09
simon.H
Thanks,  your quickly answer to me.
when i register shutter to windows service on my remote computer,
(now, my remote computer has running on windows7-ultimate version)
### first,
using sc.exe (windows service control util) .. but failed.
Showed message to me,  register success service on command mode,
but shutter not running on service
### second,
using Any2service (Third party tools) .. but failed
service register had been failed
### third (success)
using instsrv.exe, srvany.exe
copy file.. instsrv.exe , srvany file to windows\system32
cd c:\windows\system32
instsrv Shutterexe c:\windows\system32\srvany.exe
regedit
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Shutterexe
(please confirm image)
Setting of shutter my remote computer, please confirm image file
one strange thing.
it's not same shutter running memory size???
service running mode : process name(shutter.exe), memory(1,364KB or above this)
normal running mode : process name(shutter.exe), memory(2,121KB or above this)
i guess i wrote all of this about problem.
please, check and find solve to me.
so sorry and very thanks.
#4 2014-07-12 14:00
I tested it and it works fine, no problems with connectivity.
I installed Shutter 3.5 as a service using NSSM - The Non-Sucking Service Manager.
The command was:
nssm.exe install "Shutter"
A dialog will open which will ask you to specify the full path to Shutter.
#5 2014-07-13 15:15
simon.H
Oh.. It had been another way that i didn't know.
Try it and reply result on here.
Thanks.
#6 2014-07-23 09:18
simon.H
nssm service tool was good !!
now, i have been running shutter via service mode.
Thanks.
