#1 2007-02-25 18:10
mirek
SHA1 problem with large files
Very nice soft, but....
result for SHA1 (Hash from http://keir.net/hash.html , digsum from http://www.di-mgt.com.au/crypto.html ) is different!
I check file nw65ossp6.iso from Novell
#2 2007-02-25 18:33
Re: SHA1 problem with large files
No, it calculates correct MD5/SHA1!
I just checked it for several files (from 1Mb to 700Mb), against your Hash.
By the way, there is an MD5 on Novell site, not SHA1!
Try latest dev version: HasherBeta.zip
#3 2007-02-25 18:48
mirek
Hash SHA1:
61C110D183A7B3250B205D32C3F6CA1C33489F70
digsum SHA1:
61c110d183a7b3250b205d32c3f6ca1c33489f70
Hasher SHA1:
f4ec506cd0ed86346c1530141e0f49e746d7c897
file: nw65ossp6.iso
#4 2007-02-25 18:52
Where is that file?
Edited: Can you reproduce this for any other files?
#5 2007-02-25 19:16
mirek
I download  (as registered user) nw65ossp6.iso from:
http://download.novell.com/Download?bui … NVuIOvwiw~
For other checked files results are the same
#6 2007-02-25 20:41
Well, I can't download it, I don't have Novell Account.
Can you somehow share/upload that file? And when you said "For other checked files results are the same" - you meant that you get different hashes for every file that you try? I yes, can you send me the smallest one? I can't reproduce your problem, I've tried with almost 100 different files already...
What Windows version are you using? Also, can you try on other PC?
#7 2007-02-26 10:52
mirek
Share/upload that big file... it is problem
Using Hasher, Hash and Digsum, for other checked files, I get the same hashes (MD5, SHA1)
Only for Novell's interesting file nw65ossp6.iso SHA1 is different (using Hasher)
Windows XP Prof SP2. On other PC's problem is the same
sorry for my english wink
#8 2007-02-26 12:35
Can I use your login information to download that file?
I will use it only to download the file and will remove straight away...
#9 2007-08-13 12:27
Good news! smile
This problem should now be fixed. I've incorporated new hashing libraries (Delphi Fundamentals v3.28) into the Hasher. Tried hashing that problematic "nw65prodsp6.iso" and also "nw65ossp6.iso" and got exactly the same hashes as did that Hash tool!
Latest development version is updated: HasherBeta.zip
