When I tried to rename file series, as an example:
to
10.jpg,
I received a message:
“Warning, found 2 invalid Filename(s)!
2 of which has already existing new filepath.”
How I can most easily resolve that?
A very common problem. It is because you will be trying to rename file "07.jpg" into "08.jpg", while file "08.jpg" hasn't yet been renamed to "09.jpg", thus a clash occurs. The easiest solution is to insert some "dummy" character in front of new names, and rename. Then simply remove that "dummy" character and you got your desired names.
For example:
to
And then remove the "_".
Other way is... just before renaming, sort them by new name digits column in reverse order, and rename them despite the warning message. In this way, you will start from the top, renaming "09.jpg" into "10.jpg", giving room for "08.jpg" to be renamed into "09.jpg", and so on.
For example:
to
Good luck
Thank You for the second advice! Just I haven’t guessed that it will work despite the warning.
