#1 2012-09-12 20:24
Regex223
FORUM: Error Message "[i] was opened within itself"
(i) was opened within itself, this is not allowed. Why am I getting this error message when posting code? Thanks
(Adjusted the subject line, Stefan)
#2 2012-09-12 20:31
Re: FORUM: Error Message "[i] was opened within itself"
What?
Please clarify.
And... please use better description in your subject line to show what this thread is about.
#3 2012-09-12 21:16
Regex223
I was trying to post a new script code which contained (i) syntax and upon clicking submit the following error message showed up:
“(i) (i surrounded with SQUARE brackets NOT round ones) was opened within itself, this is not allowed”. Needless to say I had to change the square brackets to round otherwise I couldn’t have posted this. Try this to duplicate the error message - use this same posting but change the round brackets surrounding i to SQUARE brackets and repost.
Please let me know what happens. Thanks
#4 2012-09-13 06:55
Oh, you were talking about writing in the forum.
The square brackets in forums are usually used for formatting purposes (bold, italics, quotations...).
To post a code I recommend to writ something an hit preview, this will bring you to a new posting box. There you will have a button that looks like "<>". If you select it you can wrap your code between [ code ] tags.
Your error was because [ i ] is normally used for italics.
#5 2012-09-15 20:49
As SafetyCar already suggested, you should paste your code within the [ code ] tag, it will fix your issue.
For more info read BBCode help: http://www.den4b.com/forum/help.php#bbcode
