Hooker:Auto start in hidden mode
Navigation   Arrow Return.png Hooker
Auto run on login
To automatically start Hooker when user logs in you can use a built-in option in the settings called "Auto run on login".
On Windows Vista, 7 and 8 you may need to launch Hooker with administrative privileges to be able to activate/deactivate that option. To do this, right-click on Hooker executable and choose "Run as administrator". This issue is also described in the Compatibility article.
Alternatively, you can simply place a shortcut in the Startup folder [1].
Start in hidden mode
To start Hooker in hidden mode you need to configure the password in the Settings, which will be used for accessing the user interface.
Prior to v3.3 the password was built into the registration code and distributed upon purchase, but since v3.3 the password became a user configurable setting.
Note: Starting Hooker in hidden mode is currently available only in "Pro" version.
