#1 2010-10-17 09:59
Respect new path on fixing conflicting names
Currently if you change the destination path, after fixing conflicting names the path is removed, i think this should be solved.
I supose (maybe suposing too much since y don't know how renamer is coded) that now the function used is WideExtractBaseName(FileName). But I've remind that there was another function, that would work pretty well in this case, WideStripExtension(FileName).
#2 2010-10-31 01:22
Re: Respect new path on fixing conflicting names
Good observation. I have changed it so the path will not be stripped any more.
#3 2010-11-06 07:46
Thanks, works perfect now.
