#1 2010-10-11 09:17
Serialize bulk of 3 files, then reset counter
atthershabbir wrote:
Hi guys..
M new to X i did rnd but wouldnt get the way rename as i want.
I have placed an example what i really want to do.
For example I have a folder with 9 files as under :
As you see i want to rename in sets of 3 files.
Please help me in this as i need this to badly as i have folders with more then 1000 pics regularly as i m into product photography and i need to rename them on regular basis.
#2 2010-10-11 09:22
Re: Serialize bulk of 3 files, then reset counter
We can do this in three steps/rules:
1) Delete the whole file name first; Delete: Delete from Position 1 until the End (skip extension)
2) Use an PascalScript to serialize 3 files with the same number (MW001); PascalScript:
3) Serialize every three files from 01 to 03 (-01); Serialize: Serialize Incremental from 1 step 1 (reset index every 3 files) and pad to length 2 as suffix (before extension)
For 1 +3 See the WIKI for more about using Rules:
=> http://www.den4b.com/wiki/ReNamer:Rules
For 2.) here is the script:
 Serial, FileCount: integer;
 SerialStr: string;
//initialize:
  if Serial < 1 Then Serial := 1;
  if FileCount < 1 then FileCount := 1;
//convert number to string and pad with zeros:
  SerialStr := IntToStr(Serial);
  while Length(SerialStr) < 3 do
      SerialStr := '0'+SerialStr;
//build new file name,
  //fixed string 'MW' plus Serial plus dash plus ext:
  FileName := 'MW' + SerialStr + '-' + WideExtractFileExt(FileName);
//increase file count by one:
  FileCount := FileCount + 1;
  //reset file count after every third file:
  if FileCount > 3 then
      FileCount := 0
        //but increase Serial by one for the next three files:
       Serial := Serial + 1
#3 2010-10-11 13:02
atthershabbir
Thanks for your reply man... it was cool solution i got it working but stuck on 1 step.
I completed Step 1 & 2 successfully but stuck on 3rd step where in you said "reset index every 3 files" how do i do that? as there is no option for it.
I am attaching the screen shot below :
#4 2010-10-11 16:14
Oh, i am sorry, i do always this mistake :-(
The solution is: You have to use the latest beta because this feature was added recently only
>> http://www.den4b.com/projects/ReNamer/ReNamerBeta.zip
#5 2010-10-12 06:01
atthershabbir
Thanks for your reply man i got the Beta version and tried it out but there is little issue with the software.
If you see the screenshot the first set
MW001-01
MW001-02
MW001-03
was successfully but after that there is 04 serial coming sad
MW002-01
MW002-02
MW002-03
MW002-04
Check the screenshot below :
#6 2010-10-13 16:26
atthershabbir
still no reply buddy....
#7 2010-10-14 13:18
Looks like a bug.
I would post the question on the Bugs section. (Probably Dennis is busy and has not entered this part of the forum.)
Meanwhile, if you are in a rush, you could use this:
var I: Integer;
  If I>=3 then I:=1 else I:=I+1;
  FileName := WideExtractBaseName(FileName) + '0' + IntToStr(I) + WideExtractFileExt(FileName);
#8 2010-10-15 09:49
There was a little problem with the reset counter, it was reset to a 0 value instead of 1.
It is fixed now: ReNamerBeta.zip
#9 2010-10-16 05:00
atthershabbir
thanks guys... i got it workin well now wink
