#1 2010-08-29 16:32
Huisie
Rearrange Rules not Saving Properly
I'm having some trouble with saving rearrange rules on open and close.
As an example, I have created this set of rules to rename video files :-
Pre Vids Ruleset
However, when I close ReNamer and reopen later, the ruleset looks like this :-
Post Vid RuleSet
When I open the ruleset with NotePad, it appears that each successive rearrange rule is being added to the next one.
The preset in NotePad when created :-
[Rule8]
ID=Rearrange
Config=EXPRESSION:%28%5Cw%2B%29+%28%5Cw%2B%29+%28%5Cw%2B%29+%28%2E%2A%29;REPLACE:%244;CASESENSITIVE:0;SKIPEXTENSION:1;DELIMITERTYPE:0;RIGHTTOLEFT:0;DELIMETERS:+;NEWPATTERN:%241+%242;SKIPEXTENSION:1
Marked=0
[Rule9]
ID=Rearrange
Config=EXPRESSION:%28%5Cw%2B%29+%28%5Cw%2B%29+%28%5Cw%2B%29+%28%2E%2A%29;REPLACE:%244;CASESENSITIVE:0;SKIPEXTENSION:1;DELIMITERTYPE:0;RIGHTTOLEFT:0;DELIMETERS:+;NEWPATTERN:%241+%242+%243;SKIPEXTENSION:1
Marked=0
[Rule10]
ID=Rearrange
Config=EXPRESSION:%28%5Cw%2B%29+%28%5Cw%2B%29+%28%5Cw%2B%29+%28%2E%2A%29;REPLACE:%244;CASESENSITIVE:0;SKIPEXTENSION:1;DELIMITERTYPE:0;RIGHTTOLEFT:0;DELIMETERS:+;NEWPATTERN:%241+%242+%243+%244;SKIPEXTENSION:1
Marked=0
What it looks like after closing and reopening :-
[Rule8]
ID=Rearrange
Config=EXPRESSION:%28%5Cw%2B%29+%28%5Cw%2B%29+%28%5Cw%2B%29+%28%2E%2A%29;REPLACE:%244;CASESENSITIVE:0;SKIPEXTENSION:1;DELIMITERTYPE:0;RIGHTTOLEFT:0;DELIMETERS:+;NEWPATTERN:%241;SKIPEXTENSION:1;DELIMITERTYPE:0;RIGHTTOLEFT:0;DELIMETERS:+;NEWPATTERN:%241;SKIPEXTENSION:1
Marked=0
[Rule9]
ID=Rearrange
Config=EXPRESSION:%28%5Cw%2B%29+%28%5Cw%2B%29+%28%5Cw%2B%29+%28%2E%2A%29;REPLACE:%244;CASESENSITIVE:0;SKIPEXTENSION:1;DELIMITERTYPE:0;RIGHTTOLEFT:0;DELIMETERS:+;NEWPATTERN:%241;SKIPEXTENSION:1;DELIMITERTYPE:0;RIGHTTOLEFT:0;DELIMETERS:+;NEWPATTERN:%241;SKIPEXTENSION:1;DELIMITERTYPE:0;RIGHTTOLEFT:0;DELIMETERS:+;NEWPATTERN:%241;SKIPEXTENSION:1
Marked=0
[Rule10]
ID=Rearrange
Config=EXPRESSION:%28%5Cw%2B%29+%28%5Cw%2B%29+%28%5Cw%2B%29+%28%2E%2A%29;REPLACE:%244;CASESENSITIVE:0;SKIPEXTENSION:1;DELIMITERTYPE:0;RIGHTTOLEFT:0;DELIMETERS:+;NEWPATTERN:%241;SKIPEXTENSION:1;DELIMITERTYPE:0;RIGHTTOLEFT:0;DELIMETERS:+;NEWPATTERN:%241;SKIPEXTENSION:1;DELIMITERTYPE:0;RIGHTTOLEFT:0;DELIMETERS:+;NEWPATTERN:%241;SKIPEXTENSION:1;DELIMITERTYPE:0;RIGHTTOLEFT:0;DELIMETERS:+;NEWPATTERN:%241;SKIPEXTENSION:1
Marked=0
I've had a look through the forums, but can't find anyone else with this problem.
I'm running Windows 7 x64 Ultimate and ReNamer 5.50 Beta
#2 2010-10-15 10:10
Re: Rearrange Rules not Saving Properly
There was a problem with saving configuration of multiple Rearrange rules.
I have fixed it now: ReNamerBeta.zip
Thanks for reporting this issue!
#3 2010-10-15 12:43
Huisie
Cheers, Denis
Sorry for posting in wrong section (should have gone in "Bugs").
In my defence, I thought the "bug" was me, in that I was doing something incorrectly.
Thanks for sorting this!
