#1 2010-08-20 18:14
Questus73
Web Interface Commands through link
the topic says it already:
How (if) can I put for example the shutdown-command into a allready stored link,
just to choose it on my iPhone, it opens Safari and my PC at home will shut down.
What I have in mind is a link like "http://User:Password@64.xxx.xxx.xx:Port/shutdown"
So I have it now the way, that the menu appears, but I don't want all the choices, I just want shutting down by link.
I haven't found anything in the net or forum. Is there a possibility?
Thank you
Questus
#2 2010-08-24 08:00
Questus73
Re: Web Interface Commands through link
mhhh...
is this maybe the wrong forum?
It is called "Support"
At least some reaction like "wrong question", "possible",
"Not possible", "no clue what you want/mean", "there is a workaround...", somerhing else than silence, please.
Questus
#3 2010-08-24 08:11
mhhmm... maybe the author is on vacation or involved in earning  money at work? big_smile
Be patient, sooner or later Denis may answer you, he did it ever since.
Anyway, welcome to the community Questus.
Maybe it help to read this >> http://www.den4b.com/forum/viewtopic.php?id=438
#4 2010-08-24 17:29
Questus73
OK, I understood this hint and donated 10 Euros at this moment.
Hopefully I will get an answer within some weeks otherwise I won't die
either ;-)
Regards
Andreas
#5 2010-08-24 18:47
That was not meant as an hint like that, but thank you Andreas in behalf of Denis big_smile
#6 2013-12-10 17:35
Sorry for getting back to this so late, but it seems to be already working as expected.
For example (assuming Web Interface is configured as "username", "password", "127.0.0.1", "8080"):
http://username:password@127.0.0.1:8080/action?name=alarm
This will call the "Alarm" action, but you can substitute the associated URL parameter with any of the following values:
  • Shutdown
  • Reboot
  • Logoff
  • Lock
  • Sleep
  • Hibernate
  • Monitor
  • ScreenSaver
  • HangUp
  • Alarm
#7 2019-06-10 13:07
mikeysoft
Hi, I tried this but get "Invalid query parameters!" when calling action?name=reboot (tried Reboot too).
http://user:password@192.168.100.40:port/action?name=reboot
Any ideas? Thanks.
#8 2019-06-11 09:27
The query parameter name has changed from "name" to "id", so the URL should look like:
http://username:password@127.0.0.1:8080/action?id=alarm
As of Shutter v4.3, the list of supported quick actions is as follows:
Shutdown
Reboot
Logoff
Lock
Sleep
Hibernate
MonitorOff
ScreenSaver
VolumeMute
VolumeUnmute
HangUp
Alarm
