#1 2010-08-12 13:10
Sceptic
How to reset serialization index if filename changes
Hi!
I have about 500 files in one folder, and they that look like:
I need to serialize them so that each portion of files with the same name is in order, starting from 01 each time, like:
I tried to do this with Renamer, using the Delete rule (remove two last digits) and Serialize, but I found that serialization within one folder goes like:
Please, help!
#2 2010-08-12 14:22
Re: How to reset serialization index if filename changes
Hi Sceptic, welcome!
I guess we had to write an PascalScript to achieve that big_smile
I am sure somebody will help you, if not i take a lot this evening.
Please provide real file name examples, or, at least, is the delimiter always the underscore?
Could there be more than one underscore in an file name?
#3 2010-08-12 14:38
Sceptic
Hi, Stefan! Thanks for the reply.
Yes, delimiter is always the underscore, but underscore is used all the time to separate filename parts, like "big_white_apple_01"
So: files are divided into groups, two, three or four files in each group. All the files in all the groups have the same name except last two digits, and I want them serialized in order. It looks like:
And the goal is:
And so on. Thank you once again for your concern.
#4 2010-08-12 18:38
Every the last underscore, OK.
Here is what i had in mind.
Please test this with all possible care! .... Rename only copies of your real files! ... I don't know how this works with many files.
786_red_socks_01.jpg-
783_red_socks_12.jpg-
784_red_socks_21.jpg-
785_red_socks_35.jpg-
898323_onion_is_great_01.jpg-
898323_onion_is_great_12.txt
898323_onion_is_great_72.log
898333_onion_is_great_1.jpg-
783_red_socks_01.jpg-
784_red_socks_01.jpg-
785_red_socks_01.jpg-
898323_onion_is_great_03.txt
898323_onion_is_great_04.log
898333_onion_is_great_01.jpg-
Use this script:
(Read our wiki how to use an script >> http://www.den4b.com/wiki/ReNamer:Rules:PascalScript )
  Part1, LastPart1, Part2, StoreLast: WideString;
  Number: Integer;
   LastPart1 := StoreLast;
   Part1 := ReplaceRegEx(WideExtractFileName(FileName), '(.+_).+', '$1', False, True);
   StoreLast := Part1;
   If (Part1 = LastPart1) Then Number := Number+1
    else Number := 1;
  Part2 := IntToStr(Number);
  If (Length(Part2) <2) Then Part2 := '0'+ Part2;
  FileName := Part1 + Part2 + WideExtractFileExt(FileName);
HTH? big_smile
#5 2010-08-12 19:13
Sceptic
Good evening, Stefan!
Thank you for replying once again, I've read your script and as far as I understand Pascal (not well, but enough for a female whose job is not related with programming), it does exactly what it should do, comparing the name (without extension and last digits) of the file with the next and either adding 1 to the current number, or resetting to 1 if the name differs. It looks awesome, and I can't wait to try it when I get to the office and my computer there.
I'll post tomorrow to tell if it worked or not. But I think it will!
#6 2010-08-13 08:59
and provide a few info too please: how many files, how long did it take?
#7 2010-08-13 09:11
Sceptic
Stefan, it worked!
Unfortunately, I cannot tell you how long it took to rename all the 450 files, because I wasn't anywhere near my computer: as I started the the process, I went away and returned much later, half an hour or so, and it was all done by that time. But I think there is a possibility that the problem will occur once more, so next time I try this script I will write down the time it will take to rename all the files.
Thank you oh so very much!
#8 2017-05-27 08:32
Option "Reset if file name changes" has been added to the Serialize rule in ReNamer v6.7.0.1 Beta.
#9 2017-05-30 11:20
Works (of course) for me, thanks.
