#1 2010-06-06 12:24
Hourglass icon displayed all the time
eR@SeR wrote:
Playing around with export/import functions I noticed some issues...
1. Add some files into files table
2. Copy some text to clipboard
3. "Import new names from clipboard" hit twice and you'll see "sand glass" all the time.
If you remove all files, add some of them again, it is the same thing.
3. "Import new names from clipboard".
4. Analyze dialog doesn't display what's in files table.
#2 2010-06-06 12:30
Re: Hourglass icon displayed all the time
I reproduced the first scenario and fixed the problem. Try latest development version.
I don't understand what the problem is in the the second scenario. Was it the hourglass icon as well or something else?
#3 2010-06-06 12:36
eR@SeR
About 2nd reported issue I've made a mistake cause Analyze dialog displays "Text after applying rules" not after Importing new names from clipboard. I apologize sad
I've edited that part but you moved it few mins ago smile
