#1 2010-05-04 10:43
narayan
Allow user to increase font size
Can ReNamer have a setting to increase the font size?
The font appears too small (especially on some HD quality LCD monitors).
Ideally there should be two different font sizes:
1. One common size for the text used in controls and
2. another common size for the text in the Rules and Files panes.
Users also may want to change the font (Arial, Tahoma, etc.) to their liking.
#2 2010-05-04 22:30
Re: Allow user to increase font size
I knew I had read about this somewhere: http://www.den4b.com/forum/viewtopic.php?pid=1410#p1410 FWIW, I agree with having such options, if at all possible.
Moreover, this does remind me of a request I had made more than a year back re. increasing the font size in the PascalScript window, or ideally, making the font type/size user-selectable. Since that edit area is pretty much stand-alone and doesn't affect the rest of the app., it shouldn't be hard to do at all. The discussion is here: http://www.den4b.com/forum/viewtopic.php?id=595
Denis, I don't think anyone voted against increasing the font size, so is this something we can see any time soon? smile
#3 2010-06-03 15:00
* Increased font size in the PascalScript dialog
> DONE
* Common size for the text in the Rules and Files panes.
> MAYBE in future
* One common size for the text used in controls
> Probably never going to happen. Location and dimensions of many controls depends on the specific font size.
#4 2010-06-03 16:32
> DONE
Finally! Thanks a lot Denis, and my eyes thank you too! smile
P.S. You've really been busy replying to forum posts today, haven't you? wink
#5 2010-06-03 16:40
narayan
And lot of changes in both ReNamer and Shutter too! smile  smile
