Nice software.
I have one suggestion (you may have one for me too!):
Have an option so once an event has "triggered", monitor it so if the condition becomes false it is restarted.
I've tried using "All" with the "timed reset" but, with 4 events it doesn't seem like it will ever perform the action (Sleep).
I'm using events:
1. User Inactive 59min
2. Network Usage < 10kb/s for 600 sec
3. CPU usage < 17% for 120 sec
4. Process Stops "ehsched.exe" every 60 sec
I wake my PC at 2am to take advantage of "off-peak" time, but Windows is set to sleep after 60min and it doesn't care about downloads. I could just disable Windows power management but then the PC won't ever sleep.
Thanks,
dRdoS7.
PS. I hope you can do this yesterday
It is something that I am considering for future releases, to change the logic for triggered events.
