#1 2010-02-08 17:03
pstein
NOT able to rename folders?
Much to my surprise I found out that renamer is NOT able to rename folders.
I dragged a couple of folders onto renamer window and all the files inside were listed
instead of the folders.
Is this really true?
Or do I have to enable somewhere an option?
Peter
#2 2010-02-08 17:12
eR@SeR
Re: NOT able to rename folders?
You have to enable/check in filter settings "Add folders as files" then you can rename them.
Note: Check Wiki about this  wink
