#1 2006-08-05 16:48
shonu
Renamer: Inverted Serialize
Hi
My Canon camera (analog!) is putting pictures in reverse order as it winds it up first and then starts taking pictures.
As a result, all images on a CD coming from developer is in reverse order.
Files show like this
I want this:
Perhaps I have not found the way yet to do this more sophistically, but I guess a small checkbox ("inverse") in the serialize diologue would be helpful
Thanks!
Shonu
#2 2006-08-05 18:09
dloneranger
Re: Renamer: Inverted Serialize
you could just click on the name header to sort the names into the order you want and then they would serialize in the right way
eg. afer clicking on the name header you'd get this
and then serialize the names to get the result you want
- good idea though
#3 2006-08-05 18:42
shonu
well, true I must say. Sometimes the obvious is too obvious ,-)
But as you said, such option to be added maybe would make sense still.
Thanks for the tip!
Saves me some work now!
Shonu
#4 2006-08-05 18:56
dloneranger
glad to be of help
your idea is a good one though, sometimes you may need one set of numbers to count backwards and one set forwards and in that case my suggestion wouldn't help
you could do it with pascalscript, but a checkbox would be a heck of a lot easier
i'm pretty sure dennis is very busy with work at the moment, but when he gets free i'm sure he'll consider your idea - he spends a huge amount of time adding other peoples ideas
#5 2006-08-07 18:47
Good news smile
The 'step' parameter for Incremental Serialization can be negative, for backwards counting!
You can download the latest development version from here: ReNamerBeta.zip
That will solve the problem, won't it?
