#1 2010-01-30 02:46
Redesign About dialogs, your opinions?
I wanted to do this a long time ago, because the current design has few minor issues. I basically want your opinion on whether you are going to prefer the new design, or, perhaps, you might have few ideas of your own.
  • Remove "What's New" section. Instead, use some sort of a "Changes.txt" file along side the application. This will remove the clutter from the executable. This will also allow modification of the changelog without the need to recompile the application.
  • Add version number to the About dialog. I am also planning to start using built-in version information in some near future.
  • Eliminate group boxes. Display information in a list of title-value pairs, for example:
    Author: ...
    License: ...
    Version: ...
    Email: ...
What do you think guys?
#2 2010-01-30 03:43
Re: Redesign About dialogs, your opinions?
I have no better idea right now, your idea sounds good.
But the current about is fine for me too.
The best idea is to add an kind of version or build information.
Don't forget an link to the donation side inside the about. Or general links to homepage/forum/wiki/donation.
#3 2010-01-30 09:01
krtek
Sounds good for me.
Version information was "most wanted" for quite a bit of time.
#4 2010-01-30 11:00
Yes, removing that tab it's a good idea and a "changelog.txt" is a nice solution.
#5 2010-01-30 21:21
Denis, with regards to Changes.txt, I like Winamp's approach a lot. The text file contains separate sections for each version no., that mentions the changes for that version. A drop-down in the About box allows you to select any version no. from the text file and see the corresponding changes.
Also, version info. in the exe would be great as well.
#6 2010-02-01 03:54
eR@SeR
Author: ...
License: ...
Version: ...
Email: ...
Agree. As Stefan mentioned add forum/wiki/donation links (if so remove from Help tab Donation link) and one more for future development "Translator:" info smile
Also in localized version would stand "Version: 5.60 (Russian)" for example. If possible make/update pdf help file from Wiki page for future version. roll
Totally agree as I mentioned here. Winamp approach for What's new section is the best for me. (Search option too)
To avoid recompilation, you can have both Changes.txt and internal list. Update txt only for beta(s) and when you're ready to publish new version, add txt changes to internal list big_smile
As narayan mentioned here (we could start/continue our discussion there maybe?) I would like to see this kind of beta logging. It looks better smile
Yep smile
P.S. Shutter could suffer these changes too smile
P.S. 2
Since I'm using Free Commander as file manager his About dialog is good to think about. What do you think? hmm
#7 2010-02-01 23:40
Here is a first draft version. Which one is better, Boxed or Bordered?
I will try to fit translator field as well, but donation link I think should stay in the main menu. I'd like to have a standard About dialog for all of my applications, so it needs to be as clean and as general as possible.
#8 2010-02-02 00:13
Maybe all links to sites should go into the menu items?
Web, Forum, Wiki, License, Donation.
#9 2010-02-02 09:16
I like the second option.
A donation button could be centered at the bottom.
About the changelog I like the XnView's one. It uses a "change.log", here an example of the content:
XnView v1.96.5 (LIBFORMAT v5.50) 16/09/2009:
   Added:
     * TIFF can write EXIF
     * Mamiya, Leaf, Hasselblad, Epson, Imacon & Sinar Camera RAW read support
     * AVT, Casio, Contax, Creative, Foculus, Leica, Micron, Panasonic, Rollei, RoverShot, Stmicro Camera RAW read support
     * NConvert: -cmyk_space, you can convert RGB=>CMYK
     * JPEG-XR read support
     * deskew automatic
   Changed:
   Fixed:
     * EXIF date taken - http://newsgroup.xnview.com/viewtopic.php?f=36&t=18026
     * XPM writing (const)
     * IPTC
     * DPX - 32BitsPacking option added
     * TIM2 CSM1 added
     * PDF orientation
     * Big WMF
     * TIFF 16bits grey
XnView v1.96.2 (LIBFORMAT v5.42) 05/05/2009:
   Added:
     * Zeiss LSM, Analyze, Nifti, Mrc, IPlab, ImagePro Sequence format read support
     * Kro (Autopano giga) format read support
   Changed:
   Fixed:
     * RAW embedded jpeg loading is slow
     * Folder rename - http://newsgroup.xnview.com/viewtopic.php?f=36
     * Edit IPTC
XnView v1.96.1 (LIBFORMAT v5.31) 05/05/2009:
   Added:
     * color for 3D button - http://newsgroup.xnview.com/viewtopic.php?f=35&t=17502
     * 'File type' for info or thumbnail label - http://newsgroup.xnview.com/viewtopic.php?f=34&t=17378
     * NCONVERT: smoothing factor, dct method, subsampling factor
   Changed:
     * DCRAW
     * SQLITE
   Fixed:
     * Embedded jpeg in DNG
     * Extract channel in batch convert
     * Edit embedded comment
     * PDF Fax writing
     * PS/EPS > 10000x10000
#10 2010-02-02 12:00
I would vote for the right one, the bordered. Locks more modern for me.
My design tip:
