#1 2006-07-31 13:25
Watson
Renaming files generated by PDF Ripper
Hi Denis!! First of all, thanks for this amazing program, the better I ever find for renaming files!!!
I want to use Renamer for serialize names of files generated by PDF Ripper, but I got a problem...
The files generated by PDF Ripper are in the following format:
nameofPDFfile -1_1
nameofPDFfile -2_1
nameofPDFfile -3_1
nameofPDFfile -4_1
nameofPDFfile -5_1
etc..
The problem is, while Windows Explorer sorts correctly by name, Renamer sorts this way:
nameofPDFfile -1_1
nameofPDFfile -10_1
nameofPDFfile -11_1
nameofPDFfile -19_1
nameofPDFfile -2_1
nameofPDFfile -20_1
nameofPDFfile -21_1
etc..
If I rename this way, I will got the pages in wrong sequence...
I think this happens because PDF Ripper don?t use 01 instead 1, but the fact is, there is not configuration in PDF Ripper to change this..
I try in Renamer many rules, but don?t realize...
Can you help me with this problem?!?!
Thanks in advance!!
Watson
#2 2006-07-31 17:27
dloneranger
Re: Renaming files generated by PDF Ripper
you could add this as a pascalscript rule
  BaseName, Extension: string;
  EndDigitsCount, I: Integer;
  NotDigit:boolean;
  PAD_TO_LENGTH = 3;
procedure Inc(var A: Integer);
  A := A + 1;
  EndDigitsCount := 0;
  BaseName := WideToAnsi(WideExtractBaseName(FileName));
  Extension := WideToAnsi(WideExtractFileExt(FileName));
  I:=length(BaseName);
  while I>0 do
   NotDigit:=true
   while IsWideCharDigit(BaseName[i]) do
     EndDigitsCount:=EndDigitsCount+1;
     I:=I-1;
     NotDigit:=false;
   If NotDigit then
     I:=I-1;
     if (EndDigitsCount > 0) and (EndDigitsCount <= PAD_TO_LENGTH) then
    while EndDigitsCount < PAD_TO_LENGTH do
      Insert('0', BaseName, I+1);
      EndDigitsCount:=EndDigitsCount+1 ;
  FileName := AnsiToWide(BaseName + Extension);
Change the line
PAD_TO_LENGTH = 3;
to however many digits you would like
eg  PAD_TO_LENGTH = 2;
nameofPDFfile -1_1
nameofPDFfile -10_1
nameofPDFfile -11_1
would be changed to
nameofPDFfile -01_01
nameofPDFfile -10_01
nameofPDFfile -11_01
Then you could resort and do any other renaming you like
#3 2006-07-31 18:20
Watson
dloneranger, thank you very much!!!
If I understand, I will make 2 separated operations: first, I use your script, after that, I apply my rules to renaming files. Ok?!?
In my initial tests, everything runs fine...
Thanks again!!!
#4 2006-07-31 18:37
dloneranger
Glad to be of help smile
#5 2006-07-31 19:28
Upps, I'm a bit late for giving the solution wink
Dloneranger, the code that you used as a template was written for non-unicode filenames (you remember WideToAnsi and WideToAnsi conversation?), because of the bug in PascalScript. They still didn't get back to me, but in the v4.10 I've introduced new functions that allow a workaround for that problem.
Now, if you are bored, you could convert it to unicode-friendly script big_smile
#6 2006-07-31 20:44
dloneranger
yeah - I was out of the house fixing someone's pc and just slipped that in as a quickie ;-)
ps one slight problem with the help for pascalscript is that the help box is modal, so you can't have it open whilst typing into the pascalscript editor - quick fix is just to fire up two instances of renamer
#7 2006-07-31 21:15
dloneranger
how about this
  BaseName, Extension: WideString;
  NotDigit:boolean;
  PAD_TO_LENGTH = 3;
  Extension := WideExtractFileExt(FileName);
  I:=WideLength(BaseName);
  while I>0 do
   NotDigit:=true;
   while IsWideCharDigit(WideGetChar(BaseName,I)) do
     I:=I-1;
     NotDigit:=false;
   If NotDigit then
     I:=I-1;
      WideInsert('0', BaseName, I+1);
  FileName := BaseName + Extension;
It'll have to be tested on some real unicode stuff of course
#8 2006-07-31 23:48
dloneranger
Or if you want it as a function
function NormalizeNumberLength(Fname:widestring; NumberLength:integer):widestring;
  NotDigit:boolean;
  BaseName := WideExtractBaseName(FName);
  Extension := WideExtractFileExt(FName);
  while I>0 do
   NotDigit:=true;
     I:=I-1;
     NotDigit:=false;
   If NotDigit then
     I:=I-1;
     if (EndDigitsCount > 0) and (EndDigitsCount <= NumberLength) then
    while EndDigitsCount < NumberLength do
  result := BaseName + Extension;
 FileName:=NormalizeNumberLength(FileName,5); end.
Change the 5 in 'NormalizeNumberLength(FileName,5)' to however many digits you want
Still haven't tested it on real unicode filenames, but it's fine on uk/us ascii codes
#9 2006-07-31 23:53
dloneranger
Just a thought, a forum for pascalscript functions would tidy up these functions posted all over the place
I do like to see other people work big_smile
#10 2006-08-01 15:52
Yes, a good thought, but I can't create a subforum within the forum, I will have to create a separate category of forums for it.
By the way, if you go to 'Search', and type "begin AND end" - it will find all the topics with PascalScript in it, I think smile
