#1 2005-07-07 01:00
ReNamer 2.00
As promised, past 2 weeks of Testing - ReNamer performed great, with its big bunch of new features.
Thanks to all people who spent there time on pushing ReNamer to its limits, which it doesn't have by the way smile
And to John McGrew for his positive arguing and his tricky ideas big_smile
Special Thanks goes to:
* Audio Tools Library developers - for their great work on the Audio Tools.
* Martin Djernaes - for his handy unit to read EXIF information.
What's New:
* ID3v1 and ID3v2 Meta Tags support;
* Jpeg EXIF Meta Tags support;
* FileSize and FileDate Meta Tags support;
* Rename Folders - treat folders like files, plus extended Add Folder dialog;
* improved filenames validation, added existence check and MAX_PATH limitation;
* new GUI for Settings form, with guidelines on how to increase performance;
* extended Delete rule: delete from-until specified delimiters;
* added option to the Case rule: extension always lower case;
* added option to the Serialize rule: pad to specified length;
* added option to the CleanUp rule: skip number sequences;
* added Shell action: delete file to Recycle Bin;
* added option to the Settings: save rules set on exit, load on launch;
* option to leave original extension for the new filenames entered via User Input;
* improved file moving procedure, added to popup menu;
* shell actions are executed for all selected files;
