Thank you to all of the people who participated in testing the beta version.
Apparently, no bugs were found, and ReNamer's new features performed very well!
Special Thanks goes to Nicholas Kormanik for his good ideas:)
What's New:
* Options menu was converted to the Settings Form;
* added Extra Columns: FileSize, TimeModified, TimeCreated - turned off by default;
* extended Browse For Folder dialog: Mask files, exclude Hidden files, Resizable;
* extended Serialization Rule: choice of Incremental or Random index;
* added ability to Force user defined Case for specific Fragments, in Case Rule;
* full path of the file is replaced by its directory path, in the Path column;
* improved performance of Case Capitalization: slow string concatenation was replaced with fast indexed character access;
* files icons reset when no validation on preview;
* handy shortcuts: Add Files - F3; Add Folder - F4; Preview - F5; Rename - F6;
* customizable "Drag your files here" text, via Settings Form;
* added Option to Minimize Path Column on Auto Size, which was done by default;
* added Select by Mask to the files management functions;
* added special sorting by File Size;
* added alternative view for Tabs;
* added files total size, beside the counter;
* code optimizations and cleanup;
