This is an important update, fixes some critical issues!
Problem with a graph been frozen is solved, as well as a strange behavior of the graph when timing line is changing, e.g.: system date or time has been changed, or computer was put to sleep and when awoken.
Another issue is a bad accuracy with calculating a cpu speed, it is due to the boundaries of the refresh rate... It takes around 500ms to correctly detect cpu speed, but because of the lower boundary, which is 100ms, it is impossible to produce a good accuracy, including that the cpu usage as well has to be calculated and plotted within that interval.
What's New:
* time independent graph points: plotting points by DateTime vs Usage had some issues, they were resolved by using Counter vs Usage;
* added statistics for samples counter;
* improved accuracy of detecting cpu speed;
* fixed frozen graph problem;
