#1 2009-10-06 05:21
narayan
Option to run the Action(s) NOW, without a trigger event
Sometimes,  the user has to check out if his stack of actions in Shutter work as intended.
(If the action does not bring the desired results, he can tweak the Actions and start all over again.)
It would be good if a "Start NOW" context menu  is provided.
When this option is selected, Shutter would start the Action(s) as if its event has triggered.
#2 2009-10-06 22:47
Re: Option to run the Action(s) NOW, without a trigger event
Yes, I will certainly add this option. Also, as a button from the main interface, beside Start/Stop/Options.
#3 2009-11-26 17:25
narayan
Thanks for implementing the feature. It's nice! smile
