#1 2009-09-30 15:03
narayan
Do not allow to close instance without warning
After setting event+action in a new instance, I have often closed it under the mistaken belief that it will minimize to system tray because I have set that in a previous instance.
only later do i remember that each Shutter instance closes by default; and to minimize it to tray, you have to set an option in each instance separately.
This is not intuitive.
Please change it this way:
1. Change the program's behavior consistently across all instances
2. Let the user access it through any instance (or a central interface)
3. Make "minimize to tray" as default.
    (Why would anyone close an instance after setting?)
4.  When we click on the x (close) button, ask the user "Do you want to exit? (Y/N)"
#2 2009-10-04 14:07
Re: Do not allow to close instance without warning
Each copy of Shutter.exe will have its own settings stored in Shutter.ini, I don't see a great need for a centralized storage/configuration of settings. In fact, for application like Shutter I think it is better to have this flexibility of configuring each copy independently.
I've seen many applications which do not implement this practice, and personally I prefer the current behavior where Close button literally closed the application.
This I think is an overkill. Bringing up this message would make sense if an application could loose valuable user created data when the data is not saved.
