#1 2009-09-23 03:59
Yollidon
Add rule to copy (or move) renamed files
Hope I haven't missed anything obvious here.
A rule to move/copy the renamed files to a different folder would be great.
As a possible addition to that, be able to list a folder name that would be
created, and possibly add serialization to the folder naming?
Great program. Keep up the good work!
#2 2009-09-23 15:56
narayan
Re: Add rule to copy (or move) renamed files
This is already possible with the new beta.
http://www.den4b.com/downloads.php?project=ReNamer
Use the newly added Rearrange rule.
See the ReNamer help here:
http://www.den4b.com/wiki/ReNamer
#3 2009-09-23 19:47
krtek
It was always possible.
Just add the folder path before the filename.
"C:\new_folder\"
You can do it eg. with Insert, Rearrange, Regex rules.
