#1 2009-08-29 15:17
krtek
Order of Metatags in the Insert Meta Tag dialog
I think it would be better to have:
File_FilePath
File_FileName
File_BaseName
File_Extension
order of metatags
instead of
File_FileName
File_FilePath
File_BaseName
File_Extension
as it would then go logically from the left to the right of the explicit path.
#2 2009-08-29 18:39
narayan
Re: Order of Metatags in the Insert Meta Tag dialog
I agree.
FilePath does not have the basename+extension; where as FileName has both.
In other words, FileName has two more components on the right hand side.
Therefore if the list order is based on left-to-right, FilePath should be listed first.
(And a left-to-right order is easy to look up.)
#3 2009-08-29 18:57
krtek
FilePath does not have the basename+extension.
You're a wonderful taleteller, narayan. wink
FilePath does contain both of them.
But in the main point, of having FilePath first, I see we do agree.
#4 2009-08-29 19:14
narayan
I propose we should have one additional meta tag: File_onlyPath.
Useful in manipulating paths.
#5 2009-08-30 11:50
Given C:\Path\To\File.ext, here's the naming convention I'd like to see:
File_FullPath = C:\Path\To\File.ext
File_Drive = C (No trailing color or slash)
File_RelPath = Path\To (No trailing slash)
File_Path = C:\Path\To (No trailing slash)
File_FileName = File.ext
File_BaseName = File
File_Extension = ext
The additional tags will help if we want to move the files to a similar directory structure on another drive for example. How does that sound?
#6 2009-08-30 12:44
krtek
I don't like the File_FullPath and File_Path names. We will get it even more hard to understand than it is now.
It is FilePath that stands for eg. "C:\Path\To\File.ext". It stands for this in PascalScript as a FilePath constant, in Files pane as a Path column and anywhere it is mentioned.
Getting File_Path metatag to stand for "C:\Path\To" will make everyone confused.
If you feel FilePath (standing for "C:\Path\To\File.ext") confusing, then its name would have to be changed  not only as a metatag, but everywhere. And I don't think it's worth it. And I don't think Denis would go for something like that.
Maybe:
File_FilePath
File_Parent or File_ParentPath(for "C:\Path\To")
#7 2009-08-31 13:11
The names aren't that important, the functionality is. As long as all those metatags are available, we can use any name that fits the bill.
