#1 2006-07-03 12:23
Qkid
Renamer: Renamed files popup
Just thought when you're bored smile you could maybe add some logic in to actually check whether a file in the list was renamed or not. At the moment it assumes every file was renamed but not all files might have been changed so the results popup says all files in the list have been renamed.
I guess maybe a quick check to see if Name equals New Name then use that figure instead might be more accurate.
#2 2006-07-03 16:01
Re: Renamer: Renamed files popup
Ohhh nooooo yikes
Where is logic behind it? Files will be renamed anyway, even if the names haven't changed! I think it will bring more confusion than it will bring logic. You might find useful the option called "Highlight changed names" under the Options menu. It will highlight in red color new names that are actually different from the original names...
#3 2006-07-03 19:03
Qkid
Hehe... yeah just saw that smile
These hidden functions...hehe... I need to explore more.
