#1 2009-02-09 07:16
michaelroper
Switches or shortcuts for automation
I have recently discovered Shutter and it works very well in Vista and XP, however I would like to make it shutdown or sleep in Windows scheduled tasks.  Can you tell me what switches I would use or automate the process?  I have tried to guess but without success.
Thank you
#2 2009-02-09 19:47
claprade
Re: Switches or shortcuts for automation
Sorry, but I dont see the purpose?
#3 2009-02-10 00:17
Which switches are you talking about? To automate which process?
It sounds that you are not planning to use Shutter at all.
#4 2009-02-10 08:02
michaelroper
Sorry I probably didn't explain properly.  I want Win task scheduler to activate Shutter to activate sleep mode, or one of the many other modes, at a preset time each day.
#5 2009-02-10 23:45
I haven't tried this, but can't you use the Save Links feature in Shutter and then call one of those links to do the required task?
#6 2009-02-11 23:07
Yes, the "Create Links" feature should achieve what he wants.
