Hi
Love the renamer product but I'm struggling with something I'm sure is very obvious. I have a set of .doc files in a folder that are named with a number and a surname e.g 123456789SMITH. I have rules that insert underscores and some additional date information and then another application I own comes along and moves these documents into another folder and emails them out. What I need to be able to do is get renamer to ignore the files that have already been renamed so that only the new files with the basic naming convention get renamed. Can anyone help?.
Hi dveal welcome,
- use different folders for new and already renamed files
or
- use explorer sort by date and add only new files to ReNamer
or inside ReNamer
- right click on files and check out context menu items; f.ex. selection by mask or by name length
or
- add an RegEx with someone common of your new file names, like
----Expression: (your RegEx here)
----Replace: aaaaa$1 .....where 'aaaaa' is just to see it better
----Then 'Preview'
----Then sort 'New Name'
----Then select all those 'aaaaaaYourRegEx' -files and Then Shift+U nMark them
Now disable the RegEx-Rule and work with all the other files still marked..
