#1 2009-01-10 10:36
PascalScript - FileTimeModified() and FileTimeCreated()
What's wrong with the following PascalScript?
  ShowMessage(DateToStr(FileTimeModified(FileName)));
  ShowMessage(DateToStr(FileTimeCreated(FileName)));
I keep getting "30/12/1899" for every file! Why doesn't this work? sad
#2 2009-01-11 11:49
krtek
Re: PascalScript - FileTimeModified() and FileTimeCreated()
I am getting same output. I guess it is a bug...
#3 2009-01-11 15:28
sad Guess Denis needs to look into it then...
#4 2009-01-13 17:30
You must use FILEPATH instead of FILENAME, because FileName is the preview name, while FilePath is the full path to the original file.
P.S. Sorry for delay, just came back from my holidays...
#5 2009-01-13 18:13
Yup, seems to work... smile
#6 2009-01-13 22:44
krtek
It would be nice, if you could update user manual.
From: function FileTimeModified(const FileName: WideString): TDateTime;
To: function FileTimeModified(const FilePath: WideString): TDateTime;
Cause that was what made us confused... tongue
#7 2009-01-14 08:08
krtek, that's a very good suggestion. smile
Actually, it might be a good idea if we all contributed short one line descriptions of each PascalScript function to be added to the manual. Some are self-evident by their names, but others might be a bit confusing. Also, for those who haven't ever touched Pascal/Delphi, even common things like how to write different kinds of loops like repeat-until, for etc. is confusing, since not all languages are alike.
Or maybe like the RegEx topic we can have one PascalScript topic with tips and tricks...
#8 2009-01-20 19:03
The FileName parameter is actually named correctly, because it doesn't have to be a full path, it can be a relative path to the current directory. Instead, it is the FileName variable in the PascalScript is badly named by me, because it should really be called Preview or NewName. But now it is too late to rename it, it will break all written scripts.
