#1 2008-11-13 00:58
TGB72
Files not updates when filters are changed
Just wondering if there is any way to refresh the file/folder list after change the filter options so the filter could be applied on loaded files/folder, right now after check/uncheck an option in filters (for example "add folders as files") and press "save" I need to restart Renamer and load the files/folder again
Thanks in advance for any help.
#2 2008-12-15 16:23
Re: Files not updates when filters are changed
There is no such "refresh" option. ReNamer works on static list of files. You will have to add your folders again once you change the filters.
P.S. You don't need to restart ReNamer to load more files, you can simply clear the table using right-click context menu.
#3 2009-11-13 04:05
capricorn12
How can we save a filter? Is there any ways on how to save it? Can you please include in your post the different ways? Thank you!
#4 2009-11-13 16:12
Filters settings are saved with general settings automatically. Remember, filters only apply to newly added files.
You can also save specific filter settings with presets. More info in wiki: ReNamer: Using presets
P.S. For the future, please create a new thread for new topic.
