I don't know if this helps
but take a look at the ReNamer beta ....
31 Jul 2008
* Integrated Windows XP Manifest to allow visual styling;
31 Jul 2008
Hi Stefan,
I have the build 5.30
It integrates Windows XP style (colours & font) just fine.
It is the Ad Rule window, Configuration panel which cuts the sentences in half with a font like Segoe UI as default system font, as soo as there is a return line (not with centred text! - not with on line text)
It must the the spacing selection.
Here some more print sceens to illustrate 2 exemples
Another one with a text line with a line retrun
Ps. if the usage on the forum is to post thumbnails only, please let me know.
What Stefan suggested is that you could download de beta version, to see if the problem persist... because in the beta there is a new option for visual styling.
The #3 download here:
http://den4b.com/downloads.php?project=ReNamer
ReNamerBeta.zip
For Stefan: sorry, I did not get this right in the first place
Okay, I will try the beta version.
I will get back to you anytime soon
PS. Is there a date for this beta to be a stable release?
Hi back,
Here is a post with a print screen of both the Beta & the Stable release:
it remains the same. Since the Clear Type introduction, the fonts are little larger. It often cause problems in small box designed for post Clear type fonts.
Click on the thumbnail for a larger definition
This is out topic, but the beta look is great
No.
If last beta is tested enough, Denis will decide to declare it as stable.
You may want to read >> The not easy story of the development, and the new way of things << too.
I don't know much about the back ground of coherences, so please wait till Denis came along, maybe he can enlighten us
It seems that you have configured custom fonts on your Vista or it could simply have new fonts setup by default or even the font smoothing could have caused the fonts to become bigger, while some components in ReNamer are not big enough in size to accommodate for the bigger fonts. I have increased the size of those components that caused the text to get cropped, so you shouldn't have this problem any more.
Please try out the latest dev version, and tell us if you find any other truncated texts.
P.S. Unfortunately I don't have Vista, so I can't test it my-self.
I think the ThreatOpener have
OS XP SP2, Screen LCD 1024 x 768, 15'
OS System font modified to: Segoe UI (Vista Font)
I just decide to make an test too...
I have Vista on this Laptop with an standard setup. So i have taken an look on it...
System font
My System font is
VISTA: Segoe UI , size 9
XP SP2: Tahoma , size 8
Info German
So ändern Sie Schriftart, Größe und Farbe von Desktopobjekten
http://support.microsoft.com/kb/310543
Info Englsh
How to Change the Font, Size, and Colors of Desktop Items
http://support.microsoft.com/?scid=kb%3 … &x=11&y=16
ClearType
VISTA: "ClearType" is set by default, not Standard
XP SP2: "Standard" is set by default, not ClearType
Info German
Verwenden von ClearType zum Verbessern von Bildschirmschriftarten in Windows XP
http://support.microsoft.com/kb/306527/de
Info English
Use ClearType to Enhance Screen Fonts in Windows XP
http://support.microsoft.com/?scid=kb%3 … 27&x=5&y=8
My Display resolution is
VISTA: 1280x1024 - 32 Bit
XP SP2: 1280x1024 - 32 Bit
I have testet
ReNamer 5.30_(3 Jul 2008)
till
ReNamerBeta 2008-09-18
on XP and Vista with out any visual (or other) problem.
This was an quick test only.
Here my settings on Vista and as result the UI of ReNamer:
Don't know if this helps someone
But now i know a little bit more about my system
Radio button in UserInput - "Insert in front of the current name" is cut a little bit.
Also in Serialize rule "Incremental" and "Random" buttons could be framed i.e. to be displayed in square...
