#1 2006-05-17 09:45
LawOfNonContradiction
Renamer: Case filter: ranges like delete
I would like the case filter to have some options like the delete filter
- from position 3 until end  (to preserve the case of the first two characters)
- all charaters after the first space (delimiter)
etc
cool
#2 2006-05-17 13:32
Re: Renamer: Case filter: ranges like delete
It is better for the standard rules to be generalized - for better understanding and ease of use. All that you are asking for - can be done using the PascalScript rule. Here are the sample scripts how it can be achieved:
1) LowerCase from position 3 to the end:
  Begining, Ending: string;
  Begining := Copy(FileName, 1, 2);
  Ending := Copy(FileName, 3, Length(FileName));
  FileName := Begining + LowerCase(Ending);
2) LowerCase after the first space:
  Begining, Portion: string;
  Position: Integer;
  Position := Pos(' ', FileName);
  if (Position > 0) then
    Begining := Copy(FileName, 1, Position-1);
    Portion := Copy(FileName, Position, Length(FileName));
    FileName := Begining + LowerCase(Portion);
3) LowerCase from position 3 to first bracket and extension:
  BaseName, Extension: string;
  Begining, Portion, Ending: string;
  Pos1, Pos2: Integer;
  BaseName := ExtractBaseName(FileName);
  Extension := ExtractFileExt(FileName);
  Pos1 := 3;
  Pos2 := Pos('(', BaseName);
  if (Pos2 > Pos1) then
    Begining := Copy(BaseName, 1, Pos1-1);
    Portion := Copy(BaseName, Pos1, Pos2-Pos1);
    Ending := Copy(BaseName, Pos2, Length(BaseName));
    BaseName := Begining + LowerCase(Portion) + Ending;
  FileName := BaseName + LowerCase(Extension);
smile
#3 2006-06-15 06:00
thanks that helped me sort out some functions for other scripts.
