#1 2008-09-02 23:53
Import new names VS auto preview
I was trying to manually edit a list with new names but I was having a lot of programs because it didn't seem to accept de new names
All the problem was that I had enabled "Auto preview when new files are added"
Anyway disabling it I did what I wanted, but I think you must know it roll
#2 2008-09-03 15:56
eR@SeR
Re: Import new names VS auto preview
I think that answer is no sad
Well you can find answer regarding this "problem" here ReNamer & list of files
Cheers wink
#3 2008-09-03 20:50
sorry, numers of the reply in that posts? I don't see what I'm refering
I'm talking about importing a list of files with new names
I had the "Auto preview when new files are added" option enabled and the list only was loading the files, later I discovered that this option was doing a new preview after importing the files and new names, so the new names were wasted
In that link I see something about keeping the names manually edited
#4 2008-09-04 15:43
eR@SeR
Yes, I was refering about this (under number 1.).
I thought, in the first guess, that you are saying about accepting, as you said (I interpreted - remembering), manually edited files from files table i.e. list of files.
So it's importing thing...
After you've make things more clear now, I see that I made a mistake.
I apologize tongue big_smile wink
#5 2008-09-04 23:41
That is a good point. I have implemented a little workaround which will temporarily disable the auto preview option before importing files and will re-enable (if it was previously enabled) it after the importing is finished.
