#1 2008-08-28 21:39
darthjure
Date formatting for meta tags
I've looked at the User Manual, but I'm still unclear about how to specify a date format.
I'm adding a rule as an Insert.  In the What field it has the following:
:File_DateCreated:
I want the date format to be yyyymmdd, but I don't know how to specify this format.  There must be some way to specify it in the What field, but I don't know how.
Many thanks!
#2 2008-08-28 22:00
Re: Date formatting for meta tags
Hi darthjure welcome.
A quick search for 'date format' in this forum
gives me "Note: you can format the meta tag by using menu "Settings > Meta Tags""
#3 2008-08-29 13:30
darthjure
Wow!  The user manual very clearly explains how to format the date, but not where.  There's no mention of that screen.  I swear I also searched the forums and didn't find that.
I never would have guessed that the date format was a global setting.  I thought it would need to be specified for each statement.
Many thanks!  Hopefully a future revision of the user manual will mention that.
#4 2008-08-30 13:59
eR@SeR
You could find your answer here How add date format to end filename too wink
#5 2008-08-30 21:24
The topic's been addressed often enough - http://www.den4b.com/forum/viewtopic.php?pid=2358#p2358 smile
#6 2008-09-14 13:22
I've added a little note in the User Manual that the Date/Time format can be changed from within the Settings.
