For example I input into Remove or Insert rule some letters/digits doesn't matter. It could be any other rule too...
Then when I want to reuse Remove or Insert rule inputed text remains.
Also it's related to Analyze name dialog. You have analyzed some text in there then you close it, when you open it again same text is shown from previous edition.
So I'm asking...is it possible to add an option like "Remember last input from Rule and Analyze name dialog" into Settings/General or somewhere else, so user can decide what he/she want to see?
This doesn't happen intentionally, it happens by design of the rules. There is a list of rules instances that are used and re-used for editing/adding rules, so any changes in the fields are remembered until you change them or until system changes them as a side effect of editing a rule.
I don't think it is very important...
Ok. If you say so
