#1 2008-08-13 00:27
krtek
Undo option for Preview
I would really appreciate an option to get the files table back to the state from before I've pressed Preview.
The thing is I quite often need to adjust results of applying rules (eg. by making surnames starting with Capital Letter and so on). It sometimes needs quite a lot of work to get them right. And then you accidentally press Preview instead of Rename or add one more rule to speed up the process (and AutoPreview is on) and all your work is lost... It happened to me tens of times and I still can't learn that adding a rule will ruin my previous work.
So having the option to UNDO last changes to file table would be great possibility for me. Who knows if not greater then possibility to undo renaming operation.
#2 2008-08-13 09:47
Re: Undo option for Preview
I think this is a good suggestion. smile
#3 2008-11-18 02:23
To much work and huge amount of overhead required for this feature. Sorry, not worth it.
