#1 2008-08-11 23:39
eR@SeR
Insert Rule, Delete Rule and PascalScript
I've been testing ReNamer for a several hours, and I've found 3 bugs:
1)    In rule Insert, when is used option: position 1, right-to-left, it won't skip extension.
Also position 1 isn't interpreted like in Delete rule in same occasion (right-to-left).
Example:
Statement:    Insert " 2008" at Position 1 (right-to-left)
Tomcraft - Loneliness (Live @ Love Parade 2003).avi ---> Tomcraft - Loneliness (Live @ Love Parade 2003).av 2008i
2)    In rule Delete, when is used option right-to-left, delimiter options doesn't work in some occasions.
Example:
From: position: 1      Until: delimiter: Loneliness
[x]  right-to-left, [x] do not remove delimiter
Tomcraft - Loneliness (Live @ Love Parade 2003).avi remains unchanged
It should be: Tomcraft - Loneliness.avi
and this one...
From: delimiter: )      Until: delimiter: Loneliness
[x]  right-to-left [x] do not remove delimiter
Tomcraft - Loneliness (Live @ Love Parade 2003).avi remains unchanged also.
I will suggest also to add "do not remove delimiter" individually to avoid this situation:
From: delimiter: Loneliness      Until: delimiter: )
Tomcraft - Loneliness (Live @ Love Parade 2003).avi ---> Tomcraft - Loneliness).avi
I cannot determine which delimiter I don't want to remove.
3)    Pascal script error message pops up when is added with an empty code. Maybe this is intended behaviour hmm?
#2 2008-08-12 14:13
Re: Insert Rule, Delete Rule and PascalScript
That of the delimiters happend to me other day, but I didn't posted it as a bug because I changed somethings to try, and at the end it worked. neutral
#3 2008-08-12 14:34
eR@SeR
eR@SeR wrote:
...delimiter options doesn't work in some occasions.
SafetyCar wrote:
...and at the end it worked.
I know that, here is example:
Example:
Tomcraft - Loneliness (Live @ Love Parade 2003).avi ---> Tomcraft - Loneliness.avi
In this situation right-to-left works, but in previous one doesn't (instead ss stands Loneliness).
But if you add one more letter e, to ss (ess) then it doesn't work hmm
#4 2008-08-17 18:37
"Skip extension" option is associated ONLY with "suffix" option, while "right-to-left" is ONLY with "position". At that is why you also don't see the "skip extension" option in the final statement of the rule when "position" is used.
This one is a logical problem/bug rather then functional. When "right-to-left" option is used the filename gets reversed, but the delimiter wasn't. So in order to make your case work you would need to reverse the delimiter character-wise when you are using "right-to-left" option. Anyway, I have changed that behaviour and now your example will work as expected. Thanks for reporting smile
3) Pascal script error message pops up when is added with an empty code. Maybe this is intended behaviour?
Yes, this is correct behaviour. PascalScript requires the code to contain at least "begin end.". And it wouldn't make any sense adding empty PascalScript rule, so I am not considering to change this behaviour.
#5 2008-08-18 17:23
eR@SeR
I know that fact before your explanation and it's obvious of course tongue
I see more natural to interpret position with "skip extension" because you'll mess up your filename and you get nothing sad (look example under 1)). Then I don't see a point of "right-to-left" option if you "touch" extensions sad
No need to redesign anything in there (or maybe must), just when it's ticked "skip extension" (after suffix radio button) it would be great to apply it on position too and to change the statement of course smile Next thing...
You can see on the shown example in first post or this simpler one:
Statement:    Insert "1" at Position 1                                Statement:    Insert "1" at Position 1 (right-to-left)
Tomcraft ---> 1Tomcraft                                             Tomcraft ---> Tomcraf1t
As you can see from second example (Position 1 (right-to-left)) result is Tomcraf1t. It should be Tomcraft1 like in first one example just reversed. Right?
Works fine now and no welcome wink... Just I hope that you'll reconsider this one little thing smile
...in this case both delimiters are here and maybe I wanted to remove this one ) but I couldn't smile
Like I presumed tongue
Yes, that I figured out when I saw in error message "Error: Unexpected end of file"
Yes, silly me :S
Sorry for reporting this anyway roll
#6 2008-08-19 13:44
Result:          Tomcraft ---> Tomcraf1t
Fixed.
I don't want to over-complicate these generalized rules with too many options. You can do so using PascalScript wink
This is easy to do, but this will render previously saved presets invalid, where option suffix is used with skip extension. So I don't think I should do this, at least not now.
#7 2008-08-19 15:21
eR@SeR
Fixed.
Nice work smile
Mine preposition would be...just move/rearrange "do not remove delimiter" below "From" delimiter and add it below "Until" delimiter and that's it big_smile I think that isn't too many options just arranging thing. I just give mine opinion/argument which you don't have to accept of course tongue You decide wink
Well, for now it's not needed. I just wanted to inform you and maybe complete Delete rule with this one little thing tongue
OK, look what you can do to change this in future somehow if you want of course roll... like I said
#8 2010-01-23 17:24
eR@SeR
After renaming file like "Sv.Vasilije Ostroski.jpg" to desired "Sv. Vasilije Ostroski.jpg" using:
1) Insert: Insert " " after "."       (After text: radio button)
I get "Sv. Vasilije Ostroski. jpg" messing file extension.
Will you change it at least for After text:?
roll
#9 2010-01-23 20:25
Would make sense to me.
For "before text" and for "after text".
Till then one may use this old trick "Use an other symbol as filename/extension delimiter"
as an work around, which belongs to the ReNamer module dogma:
1) Replace: Replace last "." with "#"
2) Insert: Insert " " after "."
3) Replace: Replace last "#" with "."
HTH? ;-) and don't prevent Denis to think about this improvement.
#10 2010-01-25 13:00
eR@SeR
Previous discussion was related to Position not "before text" tongue
Excellent solution would be if "Skip extension" affect "Suffix:", "Position:" (Right-to-left too) and "After text:"
Note: Text to describe where skip extension is used. (as in Remove, Replace rules...)
HTH?
Yes I know that, I could replace extension dot with any acceptable character (@,$...) but as you can see that are 3 rules. Why use 3 when you can use 1? wink
P.S. Sorry for late reply.
