Today I tried to edit a big amount of names, and (obviously) it was very slow, and once it was done I started a new project, and this was also very slow, and I think this could be optimized this way:
- It look like it was thelting the rules, and reaplying the changes once removed the rules.
- But if you use the option of "clear all" the files disappear extremely fast
- Doing that before the new project starts very quick.
Well, it's a problem of preview settings but... Could the software clear the files table before doing other things to make it faster?
Disable Autopreview options in Settings/Preview when working with large amounts of files.
And you won't have that problem. You will be able to apply preview only when you will be ready for it.
Yes I know, but I'm just asking if it could be optimized for those cases...
v5.40: Fixed contradiction between Importing feature and Auto Preview option
