#1 2008-05-22 17:16
microdcc
Serialize in Increments of two (Odd/Even)
This is my first time using the Renamer program & so far its been very good - but I am having trouble figuring out how I can get it to name files in odds and evens.
I am trying to rename files that are named serially to numbers that increase by two - I know using the serialize and remove will help, but it doesn't replace the original number - can anyone help?
Here are my filenames:
000001odd
000002odd
000003odd
000004odd
etc.
I want to change them to:
000001
000003
000005
000007
etc.
#2 2008-05-26 21:03
Re: Serialize in Increments of two (Odd/Even)
To remove the original name, use Delete rule: from position 1, until the end, skip extension.
To insert new numbers as ODDs, use Serialize rule: index start at 1, step 2, pad to length 6.
To insert new numbers as EVENs, use Serialize rule: index start at 2, step 2, pad to length 6.
