#1 2008-03-22 13:51
clage
Multi-user?
I've downloaded Shutter 2.90 today and I'm  testing it (on Win XP)
Question1:  Is it possible to use Shutter on a system with multi users?
Question2:  Is it possible to make Shutter work correctly while using fast user switching?
I've made some setup under my user profile and the idea is that this setup will be active for all other users, but I see it only work when logged in with my user profile.
#2 2008-04-06 14:42
Re: Multi-user?
Yes. You just need to put the link to Shutter into "autostart" folder or into "run" registry item, for All Users.
I never tried it. Is there something going wrong?
By the way, you can also try using Shutter v3 Alpha
