#1 2008-03-18 21:12
pstein
Number of changes not correct displayed
Assume I loaded 30 files into ReNamer.
Due to convenience reasons I applied to all of them a certain replace rule.
However this replace rule is not applicable to all of them but only to 5.
ReNamer performs the replace function corrently to the 5 file names (only) but
tells me in the popup that 30 files are renamed correctly.
Could ReNamer tell me in the next version just the number of file names
which are REALLY renamed?
Peter
#2 2008-04-06 15:07
Re: Number of changes not correct displayed
Application simply renames all marked files, and it does display the number of files which were "really renamed". Names of files don't have to be changes in order to be renamed.
Right-click on the files table, and go to Marking, and use "Mark only changed files" option. This will mark files for renaming which did actually change.
P.S. This topic will be moved to the "Help and Support" section.
